67 Cuda Headliner Trim Removal
pastortom1
Zephyrhills, Florida
Is there a trick to gettin' these steel trim pieces down ?
On most A's, they come off pretty easily.......On this 67 Cuda Notch, it's nearly IMPOSSIBLE to get it to come out.......
I noticed that they have a "lip" full length, that is tucked UNDER the stainless trim on the body above the window.......When I attempt to pull the trim piece out, I must pull down and IN at the same time to even BEGIN to get it to budge......I'm afraid that something is gonna break or bend.......
I need some expert advice on this one........I need to paint this trim and the pillar trim too......I HATE to do it on the car.........If someone can chime in with a trick or two, PLEASE do............. :clock:
Sometimes they glue the roofrail trim piece during installation which makes it a beeatch and with years of age, the roofrail trim rubber backing congeals to the metal.
I removed my roofrail trim first.
I have the same problem. Did you ever figure out how to remove the trim without damaging it? thanks! Kim
