BT67Dart
I'll look into norms.... what experience did you have with the 67 column?Don't bother with the 67 column, been there.
Call Norm's Speed Shop and get a redone bolt in 68 column.
I did it and have no regrets.
Looks like you had some challenges with that column to say the least. The ER-16 steel bearing with the bronze sleeve looks feasible, would be able to withstand header heat as well vs. the plastic bearing insert. When I rebuilt a column for a 68 Barracuda, I had a bronze bearing made to fit. Worked like a champ.It fell apart.
The lower plastic bearing/retainer is a failing point, no availabile steel bearing replacement, parts are not easy to find or interchange with other years.
There is a bearing some say fits, but it doesn't.
67 is an intermediate year, shares some things from earlier years, some from later, some good (threaded speedo), some bad (steering column), some 67 specific.
67 Steering Column - Help
I bought it, it doesn't fit at all, still sitting on the shelf.The ER-16 steel bearing with the bronze sleeve looks feasible, would be able to withstand header heat as well vs. the plastic bearing insert.
Nice find! Sent a message to seller.
Wise man.I am taking the path of swapping out the entire column instead of the piecemeal approach
Dang....learn something new every day - thanks !The columns are different 67 to 68/69.
You can take an entire 68/69 column and use it in a 67 and visa versa. many of the parts are not interchangable internally.
Biggest difference is the OD of the column is larger in 67 so the bushings etc don't fit.
You will also have to relocate the backup light switch to the console. It's a different switch and should be part of the console harness
67 floor shift on the left
68 column shift on the right
Steering wheel end
Bottom end
Top end
68 tube fits inside the 67 tube
Bottom end
That shows you have class and good taste.And wouldn't you know I have a bunch of 1967's
Thanks....but wouldn't you know my best one is most likely the 67 - 3 on the tree I took out to put in an automatic....That shows you have class and good taste.
67 is the best year
