67 Dart Resto w/5.7 hemi
67limecrazy
Kissimmee, Florida
Well Guys it has been a while now that I started this project and it has come to a point were I will share some pictures with you.
I will start with the begining when I first brought the car. I shall keep posting till the car is fully running.
Hope you guys are enjoying.
That is a very cool project and it looks super solid! I really like the color and the metallic in the green really makes it pop! Keep the progress picts coming!
Joe
:toothy10:Old Rear Out. Gone with the Wind.
New one in with Posi Auburn
Managed to get these rims in off of a ford and they seem to fit just right. I will cut the lip ans use a 3mm spacer and it should work out prety good.
I also installed Fiberglass Hood with the pins.
Motor Going innnnnn...........
The best is yet to come..................
Not much space on the passenger side.
Well it is inn. Now comes the good part. All the rest of the mess on wiring.
By the way this is how it looks with the rims.
Looks sweet!
BTW, please excuse my ignorance, is that a car or truck hemi?
Well It started out this way. The Block comes from a Police car that was overheating and I got Dibs on it. Then I bought a Donor truck and used the accesories out of it including the computer and wiring harness.
Check these out!!!
Almost to the point of getting this Baby running. Just waiting on a few parts to come in and then see if we get it to roar the way it should.\\:D/
f-ing sweat car, i love the post way better. are you running a v8 k-member or slant 6?
most important question to me---->. what size tire and wheel are the back ones? stock leaf hangers i assume by the looks?
I am running a V-6 K-Member and as far as the springs they are stock and location the same. I am running 275/70/15's in the back. To get the right look I had to trim the fenders so I can fit a 3mm spacer without having to mini tub the same. Turned out the way I wanted it.
I am positive that your pictures here are not doing the paintwork justice. How about another close-up shot for us to see, and tell us what you did for paint.
Please.
Please.
The paint that was used was PPG the new Charger Lime Green, However I wanted to add something different therefore some green pearl was added to the clear coat. The stripes and the hood are flat black and painted not Vinyl. As Far as a good picture for some reason everytime I take the car Outside it has been overcast. Let me see if this weekend I can take it out and See if I get some justice. Also to mention it has not been wet sanded yet. So when that is done you well know that the paint will stand out a hole lot more. What are you considering for yours? I know it is hard to decide but I know that you will come up with something nice. You seem to have the right taste for it.
Very nice, I am doing the same except using a 2007 Charger 5.7 Hemi. It has not been boring to say the least. Any reason you went with the 8 1/4 instead of the 8 3/4 rearend. What tranny are you using?
First off rear end was a freeby. Second the tranny is the original one from the donor truck 45RFE just added the housing in the rear sold by S&P. Had to fabricate a bracket to make it work but it is up and going. Also the tranny dip stick didnt work so I had to order a LOKAR one for it. I understand you didnt bore it but you could atleast throw in a cam and some heavier springs.
Good Luck.
Well guys this is what it is loking like so far I am trying to keep most of the wiring out of sight. The ones you see on the right will be also concealled.
Give me your input!!!!!!!!!
