[Found!] 69 Dart - Circuit Board Pin Connector - Fuel Gauge Side
billsdartgt
Puyallup, WA
As the title says, I am looking for the pin connector plug that connects to the circuit board on the fuel gauge side, digging into why my fuel gauge won't work and found a little wiring destruction.
the plug shown is on the alternator side, you can see the one missing where it appears there was an issue with the pins I assume
Copper pads at fuel gauge attach look horrible. Maybe that's the fuel gauge problem? If so those wires could be attached with ring terminals, same as how your amp gauge is attached. You could add a jumper with ring terminal at both ends to get the 5 volts from temp gauge to fuel gauge if necessary. Good luck with it.
Thanks for the info, I ordered new boards from year one, hope to not have to pull this cluster out again
I may have one, but can't check until later tomorrow.
I will let you know and post pic if I find one on extra wiring I have from a parts purchase years ago.
