local guy has some parts i'm buying says he has a amd windshield gasket ...i know i will need one some day
are the hard top gaskets and the converts
thanks nutz
thanks nutz
same as mine,not sure what the ht has
yes but is the gasket the same.....maybe with a different lock stripThis was just covered recently, the "67" style lock strip along the bottom of a 69 vert gasket. Richard (69bfan) stated the correct part number for the strip and the gasket...
Can't see it. That and a Vert windshield is generally taller than a hardtop or coupe.yes but is the gasket the same.....maybe with a different lock strip
the same?are the hard top gaskets and the converts
The actual windshield is the same convertible and hardtop...just looked at amd web sight they offer with or without lock strip for 68/69 dart and cuda
ill see what he has ,sent him part # ht and vert had same windshields
thanks
sorry miss read it thanksThe Precision gasket part numbers are for the windshield gaskets, the windshield part numbers use the NAG system. The Precision Rubber Company uses the the the last three or four numbers of the NAG identifier as part of their part numbering system. Sorry for any confusion.
As stated above, the windshields are the same. The gaskets, 690 series, differs in the lower section adjoining the cowl with configurations of the lower lock strip / reveal trim.
