73Swinger18
The engine...
My #8 intake valve stem tip mushroomed. Not sure why it did, there was no other signs of damage to the rocker or other components. I took both heads back to the machine shop under warranty and they redid the valve seats and measured the stem heights. After I installed the heads and during the tune up, I put my IR heat gun on each header tube. The #7 tube measured around 220F. The rest measured around 450F (in drive, idling in the driveway). The #7 spark plug looks brand new except for the timing mark on the ground electrode. There is absolutely no sign of fuel on the base ring. The insulator is bright white. I checked for spark with a gap spark tester and it had a nice bright spark. I put a new plug in and no difference. Compression checked good. I pulled the valve cover off and marked my push rods and cranked the engine. They all spun and the rockers went up and down as usual. With my finger over the spark plug hole while cranking, it produced strong suction/pressure. I'm worried that there is not enough fuel getting to this cylinder. I pulled the carb and made sure the transition slot was square. I'm out 1.5 turns on the mixture screws and idling in drive around 700 RPM. Vacuum is 8" in drive. The only thing I changed from my previous setup was that I did not block the heat crossovers this time. I can't recall measuring the temp on that tube before though either. Should I be concerned with a 200 deg split on this cylinder? Thanks!
- Original 318 bored 0.020
- Original heads with larger valves (1.88/1.60)
- Sealed Power flat top pistons
- Holley 600
- Weiand Stealth intake manifold
- Comp Cam 20-223-3 (XE268H)
- Hedman long tube headers with dual Thrush mufflers
- Autolite 63 Spark Plugs
