mshred
The Green Manalishi
- Joined
- May 2, 2008
- Messages
- 3,336
- Reaction score
- 200
Yea, I clearance mine to what I thought was enough but clearly it could have gone more. The valvetrain always seemed to move okay with the engine on the stand, but I guess it can't hurt to pull the rockers and check the pushrods.I had to open and clearance mine quite a bit, and all I had were Hughes rockers and a shim. But that doesn't address the #4 issue unless the push rod bent.
Not sure if I should just pull the heads and start there with inspecting pushrods, cam lobes, lifters, and head gaskets along with the valves...or if my plan of attack should be something else to check before starting to disassemble it. My compression numbers, plug readings, and leakdown results all point to different things
