70 challenger 318 weird noise camshaft area need advice
Will do let ya know how everything looks. Thanks for the help. I don’t know how there’s scoring on the rocker shaft. Kinda weird
One rocker or all on one side?
Pull the rocker shaft first and then the pushrods on that side, before pulling the intake. Look for a bent one.
If the cam wiped a lobe there is a lot of metal in the oil and it has been pumped throughout the engine. Time for a rebuild.
Do the check for a knock by pulling one plug at a time. That pushrod may be telling you something too.
I had rod knock on my 318. I tried pulling the plugs one by one and I really couldn't tell the difference. I ended up pulling the oil pan off and sure enough I had spun a rod bearing. So bad in fact the crankshaft isn't savable. I was honestly shocked it hadn't seized first.
Good luck
The pushrod may have punched through the lifter cup.
Been there, seen that........
