70 dart 470 ci drag car build.
MOPARMAGA
A-body or nobody
Yakima Wa
I got this car in 2018 for $400.00,
It sat at my mom's until 2021 since I had nowhere to put it. My wife and I bought a house out in the country and now I have a place to work on it.
So I'm in the destruction - reconstruction phase.
Mock up.
I apologize I haven't been great at remembering to take pictures.
But here you go. I haven't named the car yet
Sorry the pictures went in recent to less recent, I give up for tonight lol
You better get Tim over there working. Just get him a case of ginger ale and get him working.
I hear he's good at running a sander. lol
Yeah he specifically said he hates that lol.
He will definitely lend a hand.
We trade work, I get Dr pepper & he'll get ginger ale
Over at rat bastids house, I Installed new cam bearings an hour ago & installed a new intermediate shaft bushing.
Going to try to get the short block together and degree the cam soon, definitely need to check piston to valve clearance since I made my trickflow heads combustion chamber 65 CC's .080 surfaced.
New cam from smcarnut Hughes 264-268 solid flat tappet
A few changes I've got since the 1st build started dropping power.
I should mention the original build was done by someone else not associated with rat bastid, lead 69.
The list of wrongs from what I recall.
Rocker shaft bolts were way to short, bent and snapped both shafts on the 2nd day Dyno tuning.
I measured the head gaskets from the last build.
They were 4.380 bore, my pistons were rubbing the gasket because of core shift I believe, it wasn't all the pistons.
Ring gaps were too small and clearaced themselves.
Rod bearing clearance was too much, I'll have to remeasure but I couldn't get **** for oil pressure.
Dipstick wasn't going down into the oil on the milodon pan I have.
Camshaft was in incorrectly.
Blueprint sheet had my pistons in at 0 deck, what do ya know after decking the pistons were out of the deck +.010
@Rat Bastid does that sum it up.
Oh the bearings were F'd up as well.
The corrections and betterment.
I Sent the pistons in to line to line coating for skirt coating.
I bought 4.410 bore @.051 thickness for a total .041thickness.
New bearings through out. +001 rod bearings.
Plateau honed cylinders.
New gas ported total seal rings.
Nothing wrong with the cam I was running but I was a little rpm limited (that could've been cam timing) but I went a few more degrees duration & a bit more lift.
Got 1.1 points more compression from 11.7 to 12.8:1 by decking my heads.
Opened up the port window on the trickflow 240 heads to Hughes valley pan size and blended it in till it was blended in lol.
Got a tunnel ram from @MidnightSwinger and am putting a matching billet blp 850 annular booster carb that I was running on trick flow single plane.
I applaud anyone who reads all that, thank you fabo for your support since I've joined
Man, you got some work to do!. If it comes down to crunch time for the mopar nats in July let me know and I will lend whatever assistance I can. BUT, if your life even remotely resembles mine you will be making your first pass in September/October if at all this year lol.
You also didn't mention the first engine build was done by a guy who should never claim to be an engine builder and was not affiliated with any of us.
Yes, you're correct & I'll surely edit the post, he was not affiliated with you or rat bastid.
This time it will be done correctly!!!
At this point I hope to get the car done & hopefully get a few runs in this season.
Soooo much to do, but I work pretty quick when I have the time and my wife will leave me alone
Or affiliated with you!, I might see him at the nats and it will be fun to ask a few "pointed questions" of him about your engine, sadly been there a few times myself. Wish there was such a thing as a magic wand so you me and rat could all be making passes together at renegade in June.
