What brand 1/4 panels did you put on the car?
sireland67 said:What brand 1/4 panels did you put on the car?
I welded some parts back in the truck today booring i know but still moving forward trunk lock bracket tail light brackets and rear bumper brakets and closeing off holes
MOUSE said:what gauge metal did you use? did you put braces on. looks good bro.:glasses7:
Not sure reb i was thanking if it protects a truck bed then it should do good for the rust not sure what it will do for the heat but it looks good lol im using dupicolor paintable under coating under the car so the metal will be sandwiched between the two coatingsHow well does the Herculiner work for heat,insulation,and preventing rust?
what metal did i use for what part ? Are you talking about the place i'm putting the fuel cell ? If so its 22 gauge
I did brace mine i used 1/2x1/2 tubing i could just hear it rattle when the car was runing and when i turn on the fuel pump it would vibratethats what i was talking about. I used 18 ...think i need to brace? Someone told me no need. I see alot of people in fabo did.
Old Tired Rebel said:Best I like the way you did your dash it looks great.
