have a 71 demon with 8 3/4 and am contemplating swapping to bbp axles 5-4.5 to match the front disc conversion but have a few questions, 1) I want to keep it cheap, using Yukon axles however if I do can I retain the drum brakes that are on there now? and if there is someone that offers drums to drop on rather than drilling the originals. Is this even possible since I have read numerous posts but all state replacing the backing plates and linings etc to allow this swap. 2) are the Green Bearings suitable for street driver use 3) does the center section have to be removed to access the spacer block when replacing the axles? Doing all of this to remove wheel spacers and air shocks to allow better wheel to fender clearance on the rear and restore some ride quality.
Thanks for your time,
