My Demon was originally a bench seat... I bought a set of buckets and reinforcement plates.. My question... Is there a template or some measurements out there so I can put in place correctly..?
Don't they use the same outer holes as the bench seat, or have holes already there? If so, set the outer seat bracket in those holes and then mark where the inner seat bracket studs are hitting the floor pan. Drill a hole, verify the seat fits, and then weld the reinforcement plate in.
My Duster pan has a angle or sloped edge built into the pan with two holes I would think that would be my starting point. ie, because my bucket seats were there, the jackwheel before me mashed them down and put a wood strip/ spacer to give him some hight while driving. But and this is a big but my car probably was a bench seat to begin with.
