72 Pro Street Dart
I would remove the torsion bars from the trunk lid,as the braces need to have thier wheel well spot welds drilled out.
I didn't took em off i just cut braces close to the tub then when i took the halve of the tub out i grind the spot welds so no holes to fill later, then cut the remaining of the brace of the hinge support and add the fabricated piece to weld the tub and support together, following the contour of the trunk support.
you can see it in this picture!
I havent update this for a while so here is a little something
The Custom Front Brake Setup Done now the plumbing and done with it for good!
wow let me say you are building on awesome dart there. but unless you have already bought the pro comp dist i would recommend you get the fire core dist.the fire core is a lot taller and clears aluminum valve covers better. now i don't know if the edelbrocks heads are like my Indy ez heads but the pro comp dist would not work with my Indy ez heads. but i did run the pro comp dist when i had my 906 headed 440 in my dart and the dist worked fine.here is pic comparing the dist. best of luck on your build and look forward too seeing it completed.Thanks Mopar65
Thanks, Dizzy still in the box, i really didnt mock it up yet but as soon as i get there i will made a decision if i go with it or go for something else, By the way how much and where you get that nice dizzy!
HI i bought the dizzy from DON at FBO. not really remember waht i cost but i am thinking around 250 shiped and that was about 2 years when i bought it. also for that price he set up my advance etc for my engine specs.but i think you might beable to buy it straight from the dealer now.
here are some links for you.
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5859423&page=0&fpart=all&vc=1
https://www.customwiresets.com/pages.php?pageid=2
hope this helps. mopar65:burnout:
hey Demon1515, looking good, gotta love "Dem A-Bodies". the build is coming together nicely!!!!! I too love the "Cowlhood"..... check mine out ...... :)
That thing looks awesome buddy, i really will try not to use mine but if i have no other option it will be the only one i will use, my car will be a EFI car and i am using a single plane victor intake from Edelbrock that is pretty tall but i will fab a throttle bode elbow with low profile design to try avoiding using the scoop but if i got no luck well it will look good anyways! :cheers:
Took couple of hrs. today to give my car some love on the floor boards before installing the new carpeting i got laying flat on my guest room king size bed!
Engine goes tomorrow to the machine shop and many other parts ordered today for it we will keep adding stuff to this bad boy!
Main studs and griddle mocked up so the machine shop can do the machining on the block like align hone, bore, decking, block plate honed, also the crankshaft job and balance the rotating assembly with fluid dampr and billet flywheel,
Clutch kit from spec clutches ordered, ARP head bolts damper bolt, flywheel bolts ordered with a melling HV oil pump wit bolt set, all from Mancini,
Here is the clutch kit from SPEC Clutches, it looks serious holding power rated at 700+ HP so i should be ok with my goal of 550HP
Simple Electronics are here long time ago just i didnt have a chance to show em to you guys, A new MSD Pro Billet Distributor, MSD Digital 6 with 2-step, timing retard rev limit and many other things i dont know yet how to use, plus a MSD blaster SS coil,
As well as the new brake plumbing, the complete brand new wiring for the whole car from head lights to tail lights, Melling HV oil pump, Oil pump fasteners, ARP Head bolts, ARP harmonic balancer bolt, Mancini Flywheel bolts, roller pilot bearing And 3 bolt Mancini cam snout bearing,
Goza Machine Shop in Acworth GA is taking care of the .40 over, balance, align hone, squared the deck, rebuild the crankshaft 10 - 10 under before balance it with the billet flywheel, fluid damper harmonic balancer, Spec pressure plate, and installing the cam bearings on the block, Mr Tommy Goza is the best cant wait to get it back to start the engine assembly and blue print!
I did took apart the 833 trany with my 6 year old daughter and we just finish yesterday rebuilding it with new bearings, tail housing synchronizers and gaskets set, trust me without my daughter i couldn't do it, she got a photographic memory AWESOME!
I am doing this car for me and never stop working on it, but as i said before everything got a price and if someone comes with what i want for it, i will sell.
Hell, I wanna see you finish it. You have done some crazy awesome stuff. I can't wait to see how clean your engine bay is gonna be. Mine is a mess lol
I went to pick up the engine from the machine shop and it is awesomely done, all the tolerances are just perfect, so i will be putting this puzzle together very soon!
