Austin Spencer
Took apart my first 727 today, it's a 1978 year out of a truck it says. The guy I got it from said that he worked with TransGo at some point and did some prototyping/early modifications with them, so I was expecting it to be a bit different here or there but there are a few things I was wondering if anyone on here knew about. There's also some general questions about the wear of certain parts, and some rust I found inside.
First for the parts I am concerned about, I've got rust on the Reverse Drum, both inside and outside. Outside has a section that is outside of where the reverse band contacts, and is very rusty, very rough.
There is also some rust on what I believe is the direct drum, but it is fully smooth and just on the surface. It also has 5 clutch rings, which from the video I was watching is 1 more than standard.
Lastly there is rust on the outside of what I believe is the Forward Clutch.
Now for the parts I am confused about. These parts differed from the video I was watching, and seem to be missing parts. First I have the accumulator piston, which was missing the spring on the outside, and had this gear on the inside.
I can't imagine this gear does anything, it just stops the accumulator piston from bottoming in the bore. I've read about people messing with the accumulator piston when the work on the valve body.
Then, my Front Servo was a different style than the one in the video I watched
The one in the video I watched had a much larger diameter spring, and the rod/valve had a whole assembly at the bottom that it was clipped into. Mine had this skinnier spring, and the part I'm holding is all that came out.
The Reverse Band was pretty worn so I'll get both new bands, I have yet to look at the clutch material in the packs. I'll be looking to get a rebuild kit where I can modify what parts I do and don't get for my setup, I believe from a shop in Oregon. Any advice I can get would be great, I am not sure what is and isn't acceptable to work with.
I also have another 727 that I may take apart in order to get some of the parts I am missing here if I need them, but it's hard to know without knowing the exact reasons why each part was modified. The other 727 is a 64 Push Button, but should have the same parts I'm looking for, and hopefully some less rusty parts that I could swap in.
