727 Lower Gear Set for street/highway use
Thanks for the math, im running 323 and would like to stick with those.
I ran some numbers as well. Using 2.94 gears, 65MPH @about 2500 RPM as you stated above. Overall gear ratio at start with a 904 trans would be 8.1 which seems to be ok for spinning tires (above 8 is usually ok, so I have read). Overall torque to the road at start would be around 4000 (includes torque converter multiplier at start of 1.8) with an engine torque of 300, reasonably possible on a small block. Should be able to get more. 3.23 gears makes it easier to spin the tires with a 9.0 starting gear ratio, RPM at 65 MPH is 2700. I think its really between 2.94 and 3.23 when using the 904 lower gear set.
i had 3.23 gear, low gear set 904 in our dart last year for our rt 66 trip. my tires are about 25.5" tall. according to the calculator i was turning about 3k at 70mph. for our smokies trip i put 2.76 gears in it. calculator says now it should be about 82mph at 3k. i know it cruises at 75 like nothing now and I'd say at 80mph it feels like it did at 70 before. either way the car could easily cruise across the country. the difference is when it goes over that 3k mark it really starts using gas. the 2.76 is still fun as hell cruising and can boil the tires. i think this year i may go with 2.94 gears. i really like those. calculator says 77mph at 3k. i think they would be a nice all around gear for our car.
A999,s have been hard to find when I looked, but I did spot a few when I was locking at lock up transmissions..... I'll take another look when I'm ready for the trans
because of your application i don't think there's really a "wrong" option here; it just comes down to whether you want to have something that's a little more itchy out of the hole and you're okay with spending that money, or just keeping the 727 and bumping up a gear ratio.
That's the beauty or the 904/998/999 Low gear sets are stock in the 998/999... So 82 &l ater model L & M body cars, Most junk yards as well as most transmission shops should be able to provide what you need...
Diplomat/Gran Fury as well as the Chrysler 5th Avenue models are what your looking for
And for a O/P something you should consider too... No reason to pay big $$$ for a low gear set for a 727, the combo you're planning would be fine with a 998/999
Avoid the L/U models, easily spotted by the input shaft, non Lock up has splines to the end of the shaft
Didn't the low gear sets only come in the lock-up transmissions?
Nope...Lock-up convertors prior to using electronic control (which showed up the same time as O/D) was clunky at best... Chrysler had lots of complaints so they dropped it around 84... But even when they were using it, it was spotty... But as long as they were using the super high geared (2.45) axles for fuel economy... they used the low gear sets to help acceleration..
Sorry to sidetrack/hijack, im currently in teardown mode of our 67 904 and looks like some hard parts. I have this spare trans #4130972, a lockup I believe. Would this spare trans have the lower gear set?
Thanks
Steve
Thanks. I was confused by this thread: How to identify a non lockup A999 transmission with pics!
Info on the net is all the place, some say all low gear 998/999 are LU, others say not the case...
I worked in a Dodge dealer 82-84, Lock-ups were the absolute bane of the tranny guy...
https://www.moparts.org/Tech/Archive/auto/22.html
Thank you. Yeah, there seems to be a lot of conflicting info out there. Too bad there's not an easy way to identify these transmissions without deciphering the pk number or taking them apart.
Yup... Mopar never made anything easy... Personally I'd probably grab one out of a late 80's Diplomat cop car... They had the 360 (cop motor) so they have the 999 with the HD planetaries & I don't remember any cop cars ever having a L/U trans..
Those low gearsets were made for the heavy and underpowered cars like the 5th Avenues and such. I've seen where some people did not like the low gearsets in A bodys, because it was too much low gear. What I would do is try to find someone with a low gearset transmission and see if you can drive it. That'd be a lot of money and trouble to go to to find out it wasn't for you. Remember, A bodies are light and it doesn't take much to get them moving. Sometimes too much is indeed too much.
I just put an A&A 2.74 low gear set in a 727 transmission for a customer. 4 pinion billet steel carrier machined for torrington bearings. The new front planetaries machined for torrington bearings actually come as straight cuts. Not cheap.
I run a LU 84 Diplomat with a low gearset. LU circuit is plugged, Turbo Action 10" tight 3400 convertor slot drive hub, A&A 4.2 lever, billet double seal front band apply, A&A front drum multi spring kit, 1 3/8" kevlar band.
Rest of trans is stock 5 clutches front and 4 rear, 4 steel planetaries. Trans is bullet proof running 11.3 1/4 mile driven 50 miles to the track with a GV/4.10 gear/26" tire/3200 rpm @ 75 mph. The myth that a LU input shaft wont hold is BS in my experience.
Last car I had was a 68 Barracuda with an 833 OD gearset and 3.55:1 rear gear which gave me a starting gear ratio of 11:1 for the street. It had P235/60R15 tires on the back. With a 340 engine at 460 ft lbs of torque, it would burn the tires in first, second, and start to grab in third. Honestly, the gear ratio was too low for that combination, but it was fun. That's why I am looking for a lower starting gear this time around while trying to keep the highway RPM's somewhat reasonable. The A999 seems like it might work, but they are harder to find and the parts may not be cheap as you say. Might need to talk to my local trans guy and get his input.
That's great you were able to make that work, sounds like it can take a beating.
This is an interesting thread. I just found it after starting one a few minutes ago. I was asking about a lower first gear. My application is a 340 and a Bbody with a 904 transmission and a 3.55 rear end. I come to this form because you guys are mostly familiar with the 340 and 904.
I pulled my transmission/engine today and looked at the transmission oil and there were some metal in it. I was surprised given this is after a recent oil change and filter in the transmission with little usage. So I think it needs to be rebuilt, even though it seems to be shifting fine.
At 65 miles an hour I am running at about 3000 RPM. But sure would like to get a first gear that is a bit lower.
What do you think about using a lower gear in my application?
Any further suggestions for building it with a lower gear? It looks like that lower gear set from AA is like $350?. Is that the only option to consider?
Thanks, Ron
I just did a quick search, there are others that offer lower gear sets for 904 transmissions( cope racing, anderson racing, etc). I would check with a transmission shop to make sure there arent other items that need to be changed out to make the lower gear set work.
Thanks, Ron
Don't know without knowing your rear gear ratio. The A bodies are light. Sometimes the low gear set in the transmission can be "too much" in the light little A bodies. They were made for big heavy 5th Avenues and such with road gears like 2.94, 2.45 and such to give them more help getting those cars moving from a stop. So with numerically higher gears, you can end up with one that's "too sensitive" off the line for a street car.
Yeah, I read what you stated as the possibility of being too much gearing previously. I do have 3.55. @Duster_Garage (wonder if he’s a member) has a good teardown and rebuild video as I have never done one before. I believe he ( I think it was him) had a 3.55 set up with 26” tires similar to mine (my rears maybe a little bit taller). His numbers were something like 2.74 or 3.91 in 1st, 1.54 or 3.73 in 2nd and 1:1 or 3.55 in 3rd. Again my rear tires are probably more like 27-28? Which would drop it a bit. I would need to check and run the calculation. But for around town seems like it could be a good set up for a heavier bbody.
It would be nice to drive someone’s set up with a low first gear as you stated before but I don’t know anyone who has a low first set up. If it’s more involved than just changing
