727 on a magnum 360
Eric Mulay
san luis obispo california
i am putting a 727 on my 1995 magnum engine.
I understand I can use the stock flex plate and make one hole a little bigger, my question is..
what torque converter,
keep seeing a " neutral " weighted converter, ? what is a neutral weighted converter?
some say get a non weighted converted, some say this neutral thing?
my transmission builder says it needs a 91 gram weighted 130 tooth converter..
if someone could help me out on this..
what is correct..?
thanks
Use the Magnum flexplate and a neutral converter.
A weighted converter has weights on it to balance the crankshaft on an external balance engine.
The weights your Magnum needs are on the flex plate.
Or, you could have a custom converter made that has the Magnum weights on it and use a standard unweighted flexplate.
Neutral and non weighted are the same thing. A new neutral, non weighted, internal, zero balance converter.
(they all mean the same thing)
Have you done this?
if you use a weighted converter....you need a non weight flexplate.....get the picture.....weights on one or the other......not both....and not un weighted....
And you used the no weight converter..
And it works..
No vibration ?
The early magnum 5.9 engine had a "neutral" flexplate like the 5.2 engines. The weight WAS on the converter in 1994, 1995, and a 1996 that I have personally worked on.
Sometime in 1996 or so the weight got moved to the flexplate and the converter was then "neutral" balanced.
So you need a weighted 5.9 magnum flexplate. Get one from a late 96-02 5.9. My local parts store had one in stock for under $50. Then you will need a neutral balance 727 converter to go with it. I had an LA 360 converter that I had knocked the weight off of to use on my magnum swap.
Also remember that LA 360 and a magnum 360 do not use the same weights!
Have you done this?
And it works..
No vibration ?
I put my setup together using 1996 5.9 Magnum, factory weighted flex plate and neutral converter.
It really doesn't matter which way you go.
Either the flex plate or the converter needs to be weighted for the Magnum motor, but it's cheaper to use the factory balanced plate and neutral converter because they already make the parts that way. (meaning you don't need custom stuff)
