cudajim
cudajim
I am wondering if I can replace my stock 904 transmission with a 727. I've got a bone stock 69 Barracuda with a 318 engine and a tired 904 transmission. Are there any advantages or disadvantages? Will the linkage all fit?
Why not rebuild what you have? Torqueflites are simple!
If you do go with a 727, you'll need to have your driveshaft shortened and acquire a different torque converter. Some disadvantages would be that they are a little heavier and use more power to turn.
I've never rebuilt one, wouldn't know how.
I'm just looking for cheap & easy.
All you need is one book. The ATSG Service Group for the 727-904.
I resemble that remark. I still know how to light a fire! lolAll you need is one book. The ATSG Service Group for the 727-904. It shows how to build both. They are the simplest three speed transmissions ever in the world to build.
A Chimp could be trained to put one together and I am not kidding. They are that simple.
That said, in your position, I would keep the 904. As said, the 727 requires another converter and the drive shaft to be shortened.
The 904 takes way less HP to drive, resulting in more power to the ground. All the more important when working with a small engine like a 318. I would not steer you wrong. This is totally something you can do. If you can do an oil change, you can build a 904.
I was going to attempt to rebuild a torqueflite until i read through some very confusing factory service manual that mentioned probably between 50 and 100 special tools that I never heard of! That scared me away forever.
You need ZERO special tools. Only thing that is required is a set of bushing drivers if changing them out.
Everything else can be hillbilly engineered.
Here's a kit that many use as a starter that is pretty complete
Transtar Super Deluxe Overhaul Kit for Chrysler TF6 (A904) 60-Up from Northern Auto Parts
PM sentthe youtube video is ok...but I got a copy of the ATSG training video for 727 that will walk you thru the rebuilt of a 727...
free ...just send me your mailing address.......the 904 is very similar to the 727
I bought a set of those large snap ring pliers at the local tool shed for about $16. But their really not needed. The only time you use them is when popping the snap ring off the output bearing but I did it for yrs. with a couple large flat tip screwdrivers. The snap ring pliers just make it easier.See.....stuff like this makes me wonder....
I happen to have the 727...watched a couple youtube videos and they had special large snap ring tools...etc....
Jeff
