Need help trying to purchase a car from California the front suspension is missing. I have located a 70 V8 K member, torsion bars, lower control arms, manual gearbox, drag link, tie rods, pitman arm, idler arm, I need a set of upper control arms, spindles hopefully with rotors and bearings with caliper mounts. I also could use a set of cam bolts and washers to mount the upper control arms. Thanks for any help that is available.
