[Found!] 73-76 upper control arms, spindel and caliper mounts
SMCARNUT
Streetsboro Ohio
Need help trying to purchase a car from California the front suspension is missing. I have located a 70 V8 K member, torsion bars, lower control arms, manual gearbox, drag link, tie rods, pitman arm, idler arm, I need a set of upper control arms, spindles hopefully with rotors and bearings with caliper mounts. I also could use a set of cam bolts and washers to mount the upper control arms. Thanks for any help that is available.
With buying the car in california shipping parts out to get the car rolling and paying shipping to get the car back to ohio I am tapped out. What really is bad is I just gave away a free in 1970 duster slant six car that had all of the parts needed to make the new to me car roll. I have no luck at all.....That is why I try to pay it forward hoping my luck will change.
Are you looking for drum spindles to use with aftermarket disk brakes, or late model 5 x 4.5" bolt circle disk spindles or early Kelsey Hays disk spindles ? Have a set of 10" drum spindles with small upper ball joint and upper "A" arms to match very reasonable. Start a conversation if interested.
I am buying a car that the K frame and front suspension is missing. So far I have used V8 K frame, lower control arms, manual gearbox, idler arm, pitman arm, drag link and tie rods. I need some sort of spindles, lower ball joints, strut rods, upper ball joints and upper control arms ( would prefer 73 and later disc brakes )
