dusterny
I have adj brgs on my 8 3/4 axles. I installed them drivers side first which was bolted in and torked to spec. I installed pass side w\ adjuster and left about.012 to .018 end play. I drive the car and hear brg noise on driver side of rear end. As I drive and make right hand turn noise will go away. Seems to be too much end play on drivers side. I don't under stand how this can be?
What holds drivers side axle to load brg? I'll pull wheel and axle tomarrow but don't know if adj problem or brg problem. It is 3.23 open 741 right now.
