44067gtdart
I am installing an Auburn gear limited slip into my 489 Center chunk. The problem I am running into is the carrier bearings are not fully seated onto the shaft. I did use a bearing installer, but it will only go flush with the top of the shaft. The bearings that are on my open carrier are fully seated. How do I get the bearing fully seated? As always all help is appreciated. Thank you.
