Matthew levangie
New Member
Hi everyone this is my first post here. I had a quick question regarding my 8.75 green axle bearing. The bearing does not seem to want to seat itself into the housing and i was wondering if someone could give me the rundown on proper installation process. The bearing has a seal and a retainer ring of some sort on it. It seems to be that ring that is preventing the axle from fully pushing into the housing. It will fully seat if the backing plate isn't on so its only holding it back the thickness of the backing plate. Should the ring push through the backing plate or stay on the outside? Any insights would be appreciated.
