8.75 rear in 71 swinger slant six car?
MoparMike1974
Maryland
Is this possible. I got a parts car and I never bothered looking under it until today. Much to my surprise its got an original A body 8 3/4 in it. 489 case, unknown gears, peg leg. Still has original flared drums and the install looks factory. If someone swapped this in they did it right and it was done a long time ago.
I found half a build sheet and of course the part with the axle code is gone. So has anyone ever seen a factory 8 3/4 in a slant car?
Is there axle info on the fender tag?
Years ago I saw a 1970 Duster with a /6 & original 8 3/4"
My 1970 Valiant 4-door with a 318 has one also.
It is more of a gear ratio selection Vs. a HP application or not.
When I was 14 or so, my brother who was a mechanic got me a summer job working at the dealer washing new cars. I washed a brand new Dodge Aspen 4 door.. Dodge Aspen on the front... Plymouth Volare on the back. My brother wanted to buy the car.. the dealer made it into a Dodge. Oddball stuff coming out of Chrysler is the norm.
Hmm, ok maybe it is original. No way to prove it unless there is another build sheet up under the dash. I looked everywhere else and even behind the glove box. Dash will probably be coming out this weekend but I dont expect to find another one.
Could have happened at the dealer too. Without build sheets you'll never know (and I have a suspicion those aren't always true). Whatever, ya got a 489 case 8 3/4 :)
Just curious, what is the gear ratio on that 8 3/4, 3.23 ?
Maybe 2.76.
67 Dart had the 3.23 with a 170 slant.
72 Duster with 225 slant had 2.76
74 Dart with 225 slant had 2.76
All had the 7 1/4s, but just for the ratio sake.
If the 8 3/4 still has the ratio tag on the pumpkin bolt yet, that could be a clue as to it being original. If the ratio tag is missing then maybe someone swapped it in cause the
7 1/4 was clunking ???
I recall seeing that with a towing package you got a 8 3/4 , can't imagine that they would offer a towing package with a slant but you don't know
It is true. The towing package included the 8 3/4" axle due to durability. I have seen many ho-hum cars come with the 8 3/4" axle. Keep in mind that by the end of the 1972 model year, they may have been stuffing them into anything just to use up the last of the inventory.
I have seen these axles in several non performance cars. Last October I traded for an 8 3/4" axle that came from a 4 door 71 Valiant.
I dont know what the ratio. Its a one legger so I cant count the revolutions. Tag is missing so I wont know until I pull it.
Yes. A /6 with tow pkg would have an 8.75.
I got one with 3.23 suregrip out of a salvage yard car.
Chock 1 wheel and turn the other to count pinion revs.
My friend Chris's parents ordered a '71 Dart four door new with a 318 auto and special order 8 3/4".
You could order them in anything!
I’m the second owner of my 1970 Dart, it had a slant 6 with a tow package, and of course the 8 3/4 rear axle. I’ll try and find my build sheet, I put it somewhere 15 years ago, I gotta remember where. Lol.
Where would the tow package be listed on the build sheet? Also, what did the tow package consist of besides the hitch?
IIRC, a 70 Dart or Valiant with a 318 and manual 3 speed on the floor had an 8 3/4 as standard.
A tow package would have an aux. transmission cooler and I think 3.55 or 3.23 gears, and heavy duty cooling. No 2.94 or 2.76 ratio.
Yep I parted a 71 Dart rubber floor mat car. /6 with 3 on the tree and an 8.75.
A friend has a all original 72 Duster /6 w/ a/c, disc brakes and an 8.75.
Yes slant six cars could be had with an 8 3/4. Have seen many over the years. 4 door slant cars too. Have seen slant cars with 8 3/4 rear, front disc and away bar.
Years ago I bought a 71 Valiant 4 door from the original owner who ordered it brand new.. he was going to do some towing with it so ordered the HD axle - 8.75 with 3.23 gears and a Sure Grip. For mileage he said he ordered it with a slant. Whatever!
Edit: it had Kelsey Hayes discs as well
Tow pkgs usually consisted of bigger radiator / fan shroud / 7 blade fans ( more blades) bigger axle and lower gears . Different applications may have varied.
One thing that i learned years ago was to never take anything for granted when it comes to options on our Mopar cars.
Keep in mind, the factory would allow an upgrade on a car to keep it going down the assembly line, but not a downgrade.
There was a lot of weird combinations that make little sense other than someone special ordered it, or on the assembly line, that's all that was available at the time when the car was being built.
I always never take anything for granted, always look at the car closely!
Also, these cars are getting pretty old now, so anyone could have changed anything years ago and it would look like it was built that way from the factory.
Repair shops were notorious for sourcing parts from junk yards and they didn't care if it was original, just as long as it fit and they got paid for the job.
This likely or may have been built in Mexico. They were very bazaar. I saw a 77 Volare Superbee. (At least that was what they called it.) With a 360 4-barrel that was not emissions allowed in US. Thus it was fast by '77 standards. So strange was this Chrysler would not allow either Dodge or Plymouth badging. It was kinda combination of both. Of course I wanted it. But not sure if it could even be licensed in Minnesota.
