No, it's not thick enough to take that much off. That's over 1/4" difference
Torque converter shell is only stamped sheet metal. This reminded me of another point.
Beware of flex plate thickness versus converter attachment. If the bolts are a tad too long and the flex plate and/or nut block on the converter are too thin, the end of the bolt can dimple the sheet metal shell behind the nut blocks. The dimples can ruin a torque converter. There is very little clearance between its internal parts.
