Then 1 . is open, no connection.Shows 0.0 when probes are touching
Read this and you can see what's inside the magic box that could be broken.What would cause it to be open?
www.forabodiesonly.com
Does not look like the meter is working. That is a stupid display I guess they are trying to say "I" as in "Infinity" or "open." But it looks like it is saying 1 something ohms. Anyhow the meter may be defective or one probe open. Try the other resistance settings.Put it on 200 setting as low as it goes. Touched both terminals reads this. Same thing with each terminal to the ground on the alternator the truck body or case of alt.
Why are you measuring a VR?Tested out another VR with the meter. Reads 1.6 ohms at 20k setting. So I think the meter works.
This is exactly what happens.First establish how the meter works.
If touching the probes together is zero, then no touching 1 . that should be infinity.
Now go back to the alternator. Is either terminal shorting to the housing? Does the meter reads infinity?
Then check for continuity between the the two terminals.
Which probes go where for this test? Key on or off?When testing the dual ballast resistors, one should be around 5 ohms and the other 0.5 ohms. But at some point the 0.5 ohms was changed. Your shop manual will say what it should be in '85.
Don't be doing random stuff like this. Meters may not be protected, and you NEVER do resistance tests on circuits which MAY have power applied.If I put one on battery negative and one on ballast resistors one reads 017 one reads 018 I think that you may be right that the meter is junk. Any suggestions on a replacement?
After doing proper between two points on ballast resistor reads 1.5 on 200 ohmsDon't be doing random stuff like this. Meters may not be protected, and you NEVER do resistance tests on circuits which MAY have power applied.
Definitely no spark.Try this. Take your alternator, "rig" a couple of wire leads, either with alligator clips or the push on flag/ spade terminals and connect them to the field terminals. hold one to a good ground, like the block, and touch the other to battery POS. In subdued lighting, you should see a spark. Sometimes you can even HEAR the spark, if your hearing is good.
Weird. I would pull the brushes. An alternator cannot charge without power/ current in the field
