I have an 833 Bbody trans and an 833 OD Abody trans. I want to put the OD gears into the Bbody trans. What else do i need to make this possible? I know that i need the OD shift rod for 3-4 and possibly the 3-4 bracket. Help please AL
B body trans and truck OD trans has the same forward shifter mounting pad and tailshaft
length. No need to swap any gears. Just install the OD with the proper linkage.
If your OD is of the short tailshaft variety for A body the main shaft won't be long enough
to be used with the longer tail of the B-body case.
I get the impression the o.p. wants to make a B-body OD trans out of parts from an A-body OD trans. So the end product will be a B-body OD.
i get the impression the o.p. Wants to make a b-body od trans out of parts from an a-body od trans. So the end product will be a b-body od.
If so, the o.p. Needs the gears from the od trans and an od main shaft in b-body length.
The main shafts are different from a 1 to 1 trans and an od.
The a-body od main shaft is too short for the b-body trans, however brewers has them in stock.
If this is the case, wouldn't a fairly common truck 833OD be much easier?
You will likely need a new Bell housing as well. The overdrive 4 speeds all have the large (5.125 I think) bearing retainer. You may be able to machine your current bellhousing to fit.
I could not fit the o/d cluster into any of my 3 cast iron non-o/d boxes. My cases would have needed to be heavily clearanced.
That's no-never-mind for you cuz the box can just go into the B-body. All you really need is a long O/D mainshaft, and bolt your B-body tail up to the A-body box. That's what I did.
Take it easy shifting into O/D, it's been my experience that, that gear is not very strong.
Yeah to the rev. parts, which is another reason I kept the box and its o/d guts together. Eventually I bought a Passon box, and cover. Nice pieces. My C.I. boxes were 69, 70, and 71.
As to the cluster-pin, I'm such a tightwad, if they show heavy wear, I just flip em over and regroove them for the woodruff key.
But I no longer use that O/D gearset. The ratios are just too wide for a 230* cammed 360.
66fs
So hang a GV on the back, and run 3.91s.Shazzam. And if you find a 3.09/direct4th gearset. Double Shazzam!!
And if you leave the GV computer in the box and hardwire that beast, through a reverse interlock relay, that GV shifts like lightning. You will not find the tell-tales in the blackies. It will bark the tires at 70plus. Ok, my S barks em at 70plus.
66fs
As to camming; There comes a point that one more cam bump takes the vehicle out of the realm of being streetable and also a point where more cubes is just a better solution.
140mph in a short wb, narrow track, first gen Barracuda, is really pushing the envelope.
The GV comments were just to excite and entice. It was a very hard economic decision for me. But, in hindsite a great sacrifice. All muscle cars shoulda come with a factory 5-speed.Doing the chunk-swaperoo gets old fast.
