I bought an OD trans that has no levers or linkage. Ive been trying to find levers and linkage with no luck. Does anyone know the part numbers for the levers? Are the truck levers the same? I have found a lot of truck levers.
i don't know if this will help you or not. but, i took a 3 +od trans out of a 81 D100 short bed pickup and all i did was changed the tail shaft and housing and installed it in my wifes 72 swinger using all of her original shift linkage.I bought an OD trans that has no levers or linkage. Ive been trying to find levers and linkage with no luck. Does anyone know the part numbers for the levers? Are the truck levers the same? I have found a lot of truck levers.
Yes they are very very hard, I found that out as wellI tried drilling levers when I did mine, the one I needed has a too small hole.
They're hardened, I guess. It didn't go well.
Thanks for the replies, Brewers has 1 set of truck levers, also a guy on eBay has a set of truck levers. I haven't seen a set of OD linkage yet. I have the Hurst shifter but no shifter plate yet. I did this conversion in my Dart but can't remember which levers I had. The linkage that came with the truck shifter are short and pretty straight.Perhaps I can help, somewhat. The disclaimer, I'm nobody's idea of an expert. Maybe a reasonably informed amateur.
I have a rebuilt but not installed 833OD to go in my 66 Valiant (currently three on the tree). The guy that sold it to me said it would be a direct fit but this has yet to be determined. Here is a photo of the levers from that tranny.
I also have an 82 D150, with the same tranny. I can verify the levers are the same, I matched them up. So if you have easy access to truck levers, it looks like these match up to a car tranny. As info, the only number I saw anywhere is the 967 on the back of the shortest lever, above.
When I set up my car linkage to compare them to the D150, nothing matched up. Everything is completely different - the truck stuff is for sure 2-3" shorter than the car stuff and the bends are way different.
Here is a photo of the current linkage under the truck. Hope this helps.
Thanks for the info and pics! Everyone Ive talked to agrees the 2298 Pad will work. I talked to Brewers and they said the truck levers will work. They had one set of OD linkage for sale for $149. plus the truck levers and shipping would $210 - $220 plus a shift plate out of my budget for now . The trans and parts are almost as much as my car costs.........pedal assy. flywheel......Yes, the truck linkages are much shorter, and pretty much more straight. Somehow my above photos only included two of the three rods of what I believe are the correct rods for your ride. Here's a photo of the last one.
As info, I was told the correct shifter plate was a Hurst 2298. Photos included. This came from what I consider to be an extremely knowledgeable source, but as yet I can't verify it as I haven't actually bolted anything up for a real-world test.
View attachment 1715272654 View attachment 1715272655 View attachment 1715272656
Sadly, as I accumulate parts based on best information, I keep hearing Johnny Cash singing about his stolen Cadillac he got one piece at a time in his lunchbox, but when he went to bolt it up but all the holes were gone...
Hopefully I don't suffer that same fate. Good luck in your search.
and don't forget the three special flathead allen sockets-screws .
That sold fast!
I may have found a set with another member...Sorry man
Yes I am interested
