[WANTED] 9" drum brake rear backing plate 7.25 rear. 1966 Dart.
Jayman62
Ambler, PA
I need only 1. I believe these are interchangable from left to right but I need one for the passenger side rear, needs to be in undamaged and straight condition.
Thank you.
According to the Chrysler literature, the 65 - 67
9 inch backing plate uses part number 2530076-7.
In 1968 those numbers superseded to 2880568-9.
Which means any 9 inch backing plate from 65-76 will work.
If the last number is even it fits the right side.
Those early ones are RH and LH due to the E-brake cable hole.
Thank you.
Plate for a 7 1/4 small bolt pattern has 4 mounting holes. Plate for the large bolt pattern 7 1/4 has 5 mounting holes, Plate for a 8 3/4 has 5 mounting holes.
