904 trans issues in need of help
Kris wolf
New Member
0klahoma
Have a 904 trans that will pull in reverse first an second no noise not slipping but sounds like you dropped a metal garbage can down the stairs filled with rocks in drive . Replaced the slip yoke on driveshaft as a cheap maybe fix ujoint was bad anyway. the fluid is fresh an clean with new filter an full. Anyone have a idea short of ripping it out to rebuild it.i thought could be flex plate but it should make noise in all gears I would think . An yes I know I need 2 clean the shop
So just for clarification; you're saying that
1) at Zero mph, there is NO noise in manual low, nor in reverse? but
there is noise in Drive @ zero mph.
2) the trans drives the car in either position without slipping?
Then I agree with @Ikopaska /post #4
Ya no noise in park reverse first 2nd an pulls finally have time to pull the pan off today will post in a few hours
Transmission fluid complety clean no metal an flex plate isnt cracked as far as i can tell put a new filter an fluid in now its sliping first gear starting out but 2nd an 3rd hold but noise is gone. I'm ordering a new trans I'm done playing with it
