CLAY72dart
The silver bolt at the bottom should I just plug this hole? It leaks fluid
Update I have finally found what it is on a diagram it is a vent port. Does anyone know if there is a reason to plug it I see some people have just wondering if I should?View attachment 1716076978
It needs to stay open.Update I have finally found what it is on a diagram it is a vent port. Does anyone know if there is a reason to plug it I see some people have just wondering if I should?
Okay will do thanks.It needs to stay open.
I had it flipped over to install the valve body when I started filling it came right out the vent hole.In your photo is the red arrow up?
This is the trans in the as mounted orientation. Note the location of the vent hole
