[Found!] A Body power brake booster firewall mount
Eric's440Duster
Barstow Ca.
Hello, I need the firewall mount assembly for the A Body power brake booster. Also the linkage to the pedal. Don't need the booster or master cylinder.
Please let me know if you can help me and the cost.
Thank you,
Eric..
I've still brackets from a '67, but I don't think I have the two braces. I'd have to dig around for them.
Hello,
I'm building a 1974 Duster. This is what I need the brackets for. Since the 67 and up engine bays are mostly identical there.
Thank you, Eric..
I'm not that good on the later A-bodies but I believe they changed the booster and the firewall bracket starting in '73.
I have installed a 440 with fender exit headers I am looking to raise my master cylinder up out of the heat pit. I was looking for a cantilever mount to do this mod. I can modify or build a custom if I need to. I would like the correct mount for my year car, if the 73 and later is different I'll be needed this later year then. If anyone can help me out I will appreciate your assistance.
Thank you, Eric..
