so i must have missed it, why did you tear the engine apart?
Just to check it since it took a front hit and the pulley was bent a little. What I found was the cam bearings were wore on the bottom from high spring pressure. Also Headers took a hard shot underneath. So It will get a refresh .
King bearings this time through out and total seal rings. Bigger Manley valves, new springs and keepers and retainers. The motor only had 790 miles. But shift light set a 8000, rev set at 8500. It has seen 9300 on the recall at times. The trans will also get some over due upgrades.
The car is also going on a diet. It had a mild steel 8pt. cage bolted in. It will now get a molly cage. and eliminate the heater and floor mount cassette . Couldn't hear it anyway. The oil coolers were in the car for the last engine " X block" , hard block filled. They will be removed. This new motor ran cool and could go round after round.
The trans was the problem with heat. But when it would flare it would pick up MPH. It seamed as if the rev between gears would act like flat shifting a 4 spd. and not pull the motor down.
Trans brake is a must. I believe foot braking had a lot to do with bushing failure in the front suspension. The car weighed 3650lbs. in factory trim with a mild cage and still went low ten's , Even the spare was in the trunk. The spare is needed to hold the factory gas tank taught. I will now make a brace to repalce the spare.
I don't know if some of you guys know that but without the spare tire carriage bolt the metal bracket has a tendency of ripping through the floor . Yes the spare holds the tank. I would go to a cell but the seats are staying in the car . With the tank in the trunk a fire wall is needed The original seats are staying in the car.
I am also going to put the car back to its original color and weld the rad support , rear deck and door numbers in. This should cause a riot on here but the car will never be sold and its a drag car at heart. This car has been wreck in the past several times since the 70,s It was a street racer that made me money. No body could ever tell it was re-bodied not even the pro's. I once caught a guy in my trunk at a show looking for the package tray numbers. Hope this answers some of the questions you all have.
News! I am going to look at another Roadrunner on Sunday. Its a sickness , But it keeps you occupied in your later years . Without dreams life would suck. I have some extra nice Duster and Demon bodies. This red 70 340 4spd. A/C Duster can now be put back on the road. I traded the 408 drive line from the brown duster and got it back from my neighbor.
I am looking for a original 2004-06 Road king fuel injected. Will barter if interested. be back tonight going down to the shop to finish the tear down of the Orange one. I'll take more pics. Steve
