Fe, same
Post some pictures of the
Well, I've been impressed with OHC for a long time. No such thing as valve train stability issues. I've owned a 2000 BMW M5 for ten years. That comes with a 400hp 5 liter, all aluminum DOHC, four valve per cylinder V8. Essentially the Ford Coyote was modeled after it, in my opinion. The exhaust is very restrictive and a set of headers and tune is worth almost 50hp. That motor is a work of art and is more than twenty years old now. Way ahead of everything else at the time. Overhead cams and variable valve timing allow you to do things that a pushrod engine only dream of. A lot of it is aimed at efficiency and fuel economy of course, but you can make some serious power. Multiple valves allow more area for flow in a given chamber area, rather than a single big valve with a lot of wasted space around it. Biggest downside with the BMW motor is the engine controller is locked up and figuring out the variable cam timing in a standalone controller is like black magic. A lot harder for a backyard hot rodder to tinker with, but the system is capable. Kinda looks like a hemi.
"Kinda looks like a hemi"
Actually, it kinda looks "tore up".
