AC Unit in 65 Dart Parts Car
zephyr
San Bernardino
I am picking parts of a 65 Dart 6 GT this weekend. I'll have limited time to find parts for my car and remove them. But, here's the thing, the photos of the car show that there's an AC unit. Can anyone tell me if this is an original unit and which, if any, parts I should get should I decide to take the AC unit. Anything you can tell me about it and the other air conditioning parts you see in these photos is greatly appreciated. Bear in mind I know zero about what components look like or whether they are present on this car.
That's a non-factory unit. All factory A/C units only has air outlets under the dash. The three of them are chromed and is approx 1 1/2" high. The control unit is above the radio.
However a unit placed in the trunk is the first time ever I see it! Cool!
That's what I suspected. So I guess an aftermarket AC unit would have no value either. It wouldn't work for a convertible anyway because I have no package tray to plumb the air through, right?
So where are the other components; the compressor, the condenser, evaporator, etc.? Do you see them in the engine bay?
The compressor and all of the brackets and pulleys have been removed.
I would grab that sucker, my rule of junkyard is take the oddities, some one is looking for that prob for years.
That's a good point. If I have time I'll grab it. I will be scrambling to get the candy canes before the owner gets tired of standing around. The car wasn't even a "parts car" until I offered him $300-$400 for some of the parts. Mainly I gotta get the wheel opening moldings and candy canes.
I would grab it if its free, hoses, wiring and all. Someone might want to Tee it into their conventional system ( if that fan runs quietly ).
More likely that someone needs a piece of it. List it on ebay.
Hell list it here, if my car had ac I would jump on it. Grab the vents also, and the package tray if it is in good shape, that should fit most mopars.
Googled just came up with a under dash unit, has to be a rare bird there.
Because they were copying the B&B design, engineering costs were minimal, which allowed the systems to be sold relatively inexpensively. This in turn allowed the DFW Big 3 to go after a much larger market. While Detroit’s prewar A/C efforts targeted the upper end of the market (Cadillac, Packard, and Imperial), the DFW Big 3 aimed solidly for the fat midsection of the market. Furthermore, while the prewar efforts were obviously targeted at selling new cars, the units from the DFW Big 3 could be retrofitted to just about any car with a trunk and rear parcel shelf. This meant that everyone who owned car was a potential customer.
By 1965, factory AC cars had a different firewall. I understand it varied on the passenger side, around where the blower motor protrudes. If you compare w/ Google Images, you should verify that was a non-factory AC car. In 1965, factory AC was so expensive that it was a fairly rare option. There were many after-market systems (Western Auto, K-mart, Sears, ...), especially as systems became cheaper in the late 1960's. I think rear AC was an option in full-size cars then (Imperial, New Yorker), but am sure those also had dash evaporators.
Re other parts to grab, that manual gear-box and mating steering column are desired, since people using headers (w/ V-8) often can't fit power steering. The rod-style throttle, carburetor, and kick-down linkage is rare and thus valuable. The PCV "stove-pipe" is rare and an easy pick. It was also used on V-8 engines then (at least my 65 Newport). A part near the driver's shock absorber top looks interesting (rare?). The 1965 bulkhead connector (indeed entire dash wiring harness) is desire-able since better power feed-thrus. I put one in my 1964 car (but won't work for 1966+). If the headliner steel bows and clips are still there, grab them, and number them as you remove. GT was a trim level, so if not dented, it can be re-polished and probably fit to a lesser car. If the front trim is there, it is valuable, though usually dented since aluminum. Everyone is looking for good front "candy-cane" trim for a 1965.
You know that everyone not in SoCal/AZ is amazed at that rust-free body. You LA guys see that all the time in junkyards, you lucky sods.
Well as I suspected I had very limited time to grab stuff so just got the candy canes, wheel opening moldings and a couple trim pieces off the back. Also got both the D-A-R-T letters. Too bad I hadn't seen your post earlier but I got the main things I wanted. Unfortunately the interior chromed trim was roached so I didn't grab anything inside.
