Adapter bushing for 1965 904 torqueflight transmission.
jpott
Active Member
Tennessee
Does any one have or know where I can get a Adapter Bushing 1968+engine Crankshaft & 1960-67 904 torqueflight converter. Want to put a newer 318 in my 1965 barracuda. The 273 bit the dust. The later 318 engine has a large hole crank the bushing would fit in rear of the 318 crank giving the torque converter snout on the 1965 904 trans a tighter fit when all is bolted together.
Is this the size ? I needed it last year, pricey but . . .
I had same issue 67 904 and tc mated with 340. I measured and had a machine shop make one...I wanted next day, so cost me $60.
$30 is a good price if it's right dimensions
My app is 1965 904 in a barracuda. 273 engine is junk. I have a 318 LA out of a 1986 ram charger I would like to use. Just a cruiser..
Short of a caliper the inside diameter of my 340 crank was a bit over 1 3/4 " with a fn tape measure. So ordered and worked.
