j par
Well-hung Member
I'm wondering if anyone has added weight in the trunk and got good results ?
Thank you, I'm tall my seat is back against the rollbar.slide your seat back as far as you can....... that's weight transfer
What bumpers? LOLevery winter.. I find I need 4 wheel drive a lot less and.... oh, you meant in a race car...
rather than add weight to the back - - maybe remove weight from the front... a fiberglass front bumper only needs 2 brackets to hold it there.. weight savings of a good 15lbs I bet..
this is exactly what I was thinking !If you are getting wheel hop with SS springs...usually the problem is the rear shocks are not long enough...as the tire plant down and the body lifts..if the shocks are too short..the rear will wheel hop...
I haven't done any clamping or unclamping.Do you have the front segments clamped? No clamps on the rear segments?
OIC... hood? fenders? fender wells... isn't it nut's - you go through all that to make it lighter and now you want to add weight!!What bumpers? LOL
EXACTLY !!OIC... hood? fenders? fender wells... isn't it nut's - you go through all that to make it lighter and now you want to add weight!!
how about shocks - 90/10's in it up front? (I know you're not going to say "what shocks?")EXACTLY !!
and what hood? LOL
Covered the question on post #7. LOLhow about shocks - 90/10's in it up front? (I know you're not going to say "what shocks?")
we have two small batteries in the trunk..each weight about 30lbs..plus there is an alternator on the car..if it wont start you can not go anywhere...
I did notice this at the crappy t&t track..When I had a home built 2x3 frame Challenger with ladder bars, I added weight - at least 60 lbs, forgot exactly, but the car became more consistent and and I won more bracket races.
When I first got my current car with SS springs, I tried some Mopar automatic drag shocks. Under bad track conditions, not only did it spin, but it also wheel-hopped. For stiffer shocks, I debated between the Mopar "stick" shocks and Ranchos, settling for Ranchos. It still spun on rare "bad track" days, but it never wheel-hopped again!
My theory is that the harder a car leaves, the stiffer rear shock is needed. If rear shocks that are too loose are used, I figure that the amount of separation is too much and too violent so the springs have to "spring" back. Once it starts, it can't be controlled by soft shocks and you get wheel-hop, especially when the track isn't good.
You don't want to have shocks too loose on the front either. But a lot depends on how well the rear suspension works. OEM shocks are fairly loose on extension, but I don't like the easy compression because it won't help keeping the weight transfered and can cause oil pan issues when coming down from a wheelstand. I know of one instance when hard finish line braking also crunched an oil pan on a friend's 360 Volare. He had fairly new OEM shocks.
As far as changing any suspension parts I can tell you money is absolutely no object, because I don't have any! I've got the brand new SS Springs, cheap Summit drag shocks set hard as I can get them, and a dana 60 that I made has no pinion snubber. so I have traction bars that are set with no slack in them. And my tires are near brand new Hoosier's 28 x 10.5 x 15. I'm getting serious wheel hop at the line and the car is pretty much dedicated to the Dragstrip. Also I have the Lakewood drag shocks up front that are adjusted as soft as possible. at this point I was looking at some free old school tricks or maybe trying to make the trick of my own with my Twisted thinking...
