Checking a set of adjustable roller rockers with hydraulic cam/lifters for the first time. Just had a few questions for those that have been around the shop a time or two.
Running Comp 1622-16.
When setting preload, comp directs to go to zero lash with no verticle movement in the push rod, then give one full turn on the adjuster. Now when I snug down the lock nut, I can tell that draws some preload out. Not much, but it's there. I just wanted to verify that I'm supposed to hold the adjuster solid as I tighten the lock nut. Also when I initially loosened the lock nuts, there was a clear snap like the PO had used loctite. Should I put loctite on these? And does anyone know the tq spec for the lock nut?
Thanks in advance gents, hope y'all hoons are enjoying the weekend!
