adjusting end play on axels
gotdust57@yahoo
i have a 73 duster with open end 8.75 and am changing to suregrip i noticed a little more end play then i want, my axels are already out and i see the adjuster on passenger axel, could someone tell me how to adjust it please? thanks
I had to do this when I changed my axels from SBP to LBP.
I just did a search on the net and found a step my step site.
Sorry but I cannot remember the site.
Hope this helps...
Torque down both sides to spec, then using the adjuster wheel, dial in how much endplay. i think the spec is .008" - .015" off the top of my head. Then there should be a lock tab on one of the axle studs, loosen the nut, place the lock inbetween the slots on the adjuster and torque it down to hold it in place
