adjusting my vac
mechanical ability? or Mechanical knowledge??? Ive done all the work on this car myself....I would agree on the knowledge part, but I disagree on the mechanical ability part...once again I followed the instructions of a pro. engine builder...it wasn't my choice I just gave him my setup and thats what he did with it...Also the same guy that was in Mopar Muscle engine build with a 500hp 318 all motor
You should be talking to your builder than. Plain and simple.
Hold him accountable.
If this is following the instructions of a "Pro" I would hate to see an amateur.
ok... No I haven't Tried a compression test on it when its warm...and I know the 18-20 initial wont run right because thats what I had it set at...It runs great right now and Im not touching it...I do Realize the cam is too big but All I need to so is stroke it and it will run better or change the cam, but I rather keep going up in HP then go down, but the last time I did do a compression test I believe each cylinder was at around 180-190 dont remember
You WILL go up^ in HP with A SMALLER CAM. and i think you need a better or different compression gauge.
Have a hard time believing that compression unless your static compression it closer to 11 then 10.........................................
What altitude did you say you live at............
static is 11.0-10.9 and dynamic is 8.222 and what cam do you think will make more HP with this setup and with the stroker?
You have the cam card or company and grind.
A cam with 240-245 at .050 would make more power throughout the range than the one you currently have. A stroker could possibly use the cam you have.
As someone mentioned earlier, maybe try setting the lash in your valves real slack (like .040) and although it may be noisy, see if that helps tame the cam some. I agree with using a vacuum advance, it`s much more street friendly when you`re in and out of the throttle. If you primarily want to drive the car on the street it would behave better with a smaller cam and a dual plane intake.
ya my cam is a comp 360s magnum, I told him I want something that I can leave in there in case I want to go to a stroker...Im moving to orange county...30 min from Pomona..I will be at that track more then less...I want to get into a small class, so the car will be both street and strip
You mean 306S?
You won't be racing at Pomona! maybe Irwindale, Barona or Fontana
306s has an intake closing event in the 85* area IIRC. The card says 79* at .015. Using that, 79*, you only have a ratio of 7.60:1, at 85* it's 7.11:1, If it's higher than 85*, it's even lower.
If you don't have a 4K stall and deep gears, it's going to be tough.
And your cylinder pressure in reality is probably 90 to 110 PSI , the bright side is ,is you don't have to worry about hi-octane fuel, also you can probably also use stock skinny radial tires because it won't be mustering any bottom end torgue. Your 60 foots will be an estimated 2.2 also. Well id be saving up for the big CID kit soon to get er out of the 14s.
You mean 306S?
your talking about dynamic compression? I have a 3600 stall and 4.10 gears not that deep but it seems to run well
I highly doubt that the pressure is that low.....The builder has the top engine programs and put all the info in and came out with 8.222 dynamic compression not 7
ok...For once I did Research for myself...I used the KB website with their calculator...It says I have 10.959 static compression and 8.263 dynamic compression...they used the IVC at 50 plus 15 which is 71
you should be able to run Pro STock at pomona in February....
check with your engine builder to make sure...
The 15 degrees is a guideline to add to you .050 number. If the tappet valve is still off the base circle .015 at 79*, how can your closing number be 71? See the problem there?
I believe you need to use the 79 number because that's where the lash ramp will be. .015*1.5= ~.022 which is your lash.
You have 7.6:1 compression right now, using a 10.9:1 number.
Try it here which is what you already found in your research. Rod length is 6.123
http://kb-silvolite.com/calc.php?action=comp2
ya that calculator ask for at 50 plus 15 its 8.221 same thing the builder said doing it with the .56 plus 15 that is
whats the effect of the lower dynamic compression?
What you currently have! It will suffer from lack of end torque.
Think how a late model 360 runs compared to an earlier 340's. That's why a cam with 20* less duration at .050 would work better for you now. You've really got no compression in the thing. It will run on regular is my guess.
You'd be better off pulling that cam and spending $200 on a new cam/lifters. Then you won't have to lock out the timing and could actually get a mech curve in the thing.
Sorry man, the builder did you no favors.
what cam should I put in that will do well for this setup and for when I go stoker?
Put a XS282S in it. That will raise the effective comp to about 8.5:1
The cam you have will work fine in a good stroker. It's fairly close to the one Mad_Dart had in his duration wise. His cam had much more lift. Maybe toss it in a bit advanced.
