adjusting my vac
if you change cams...you will need new lifters too....
ya and i spent top dollar for these lifters....Ill wait for the stroker
I re did the math
looking into this a little further. Put all the specs in the calculator. 1.6 rocker, .022" lash, installed at 106*, 62cc head, 5cc valve reliefe, Zero deck, .038" gasket, 4.140" gasket bore, 4.030" bore, 3.58" stroke, 6.123" rod, and TRUE IVC 73.5*(this is what it is with all the right specs including rocker ratio, lash and ICL) and I get 10.93 to 1 compression and Dynamic compression 8.056 to 1.
