Advice needed ...
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Have to go with cheap radial tires to get the Dart rolling.
Looking at 235 60r14 cobra GT for the rear
Need advice for the front tires
Factory small bolt rallys
Kelsey H brakes
I will get much better tires and Cragar SS rims later.
Need them for 10k miles
Tires now are dry rotted
Kelsey H brakes
Are you taking your rallyes off and replacing them with Craigers?
Looks good like that. Amd your statement there is no such thing as cheap tires anymore.
Just priced some 205-55r-16 fir my wifes car.
And Coopers are good tires, not cheap junk
Are you planning on 14s or 15s cragars? If 14s, I'd get the tires sized for the cragars, and stick em on the rallyes for now.
Otherwise, I like your rear choice. For the front, 215/70x14 cobras. I really like the cobras. Not a lot of choice out there in white letters or 14s.
U
15 small bolt Cragars from Summit
arent many 14 inch choices and rims for a dart have t o be a certain width and back space...or the wheel lip is turned up etc. these cars are a challenge finding the right tire setup. I see aloyt go to 15 inch rims, may be the way for more choices I also think a 15 inch rim dart sits a bit higher or it may be illusion...
