Aero Motive Phantom 200 Stealth fuel system
Waco Demon
Waco Tx
I'm looking at installing a Phantom 200 in tank pump I need to see how to install fuel lines from regulator to tank . Pic's would be nice thank you Harold
AN fittings on everything? re-using any of the existing lines? adding a return? making it legal for NHRA, ect?
Make sure you secure all of the lines as high up in the floorboard area as possible. I use insulated clamps, not zip ties, they frown on using them.
...not zip ties, they frown on using them.
what's wrong with zipties ?
Yes all an fittings and 1/2" hose I understand how to clamp them along the frame rail I jest don't know to get around the frame at the torsion bar area
Crackedback (on here) posted a photo years ago, drilled holes in the crossmember, inserted a length of piple (which you can buy pre-made) and welded them in, then threaded adapters on for the hose connections.
67 Dart 273 are you implying I could have cracking in this area drill another hole Harold
It's going to be Fuel Pump -> Filter -> Fuel Rail -> Regulator -> Return to tank
I have the 340 Phantom System:
tS1yr6KP9xqK9aklCqiMoH522q0Je0ZenveGJ9JFpP2oS-D9atXq8-U6dOtPIpEo7HzujaQ=w1250-h937-no?authuser=1.jpg
-qXu3kL8lBG0SAbkC8yCXyr49VQ4A9pRzEOS7y1_o1NRmxrE307llc2IYn7dZaIBgRXRLMg=w1250-h937-no?authuser=1.jpg
FcIYzHiUjpeeT75r_cN9nR-IKdXHQPwq5CZicJSibEpKZklxDZ1AVqsnSAlnhXgeWHkG-bg=w1250-h937-no?authuser=1.jpg
2P3kMgHGyClYFmMt6Xd9eLSLfoDzOu9l9-pHvNAhgxWr-WQf60QxeLIBrQ2T_zhGLAPe5XQ=w1250-h937-no?authuser=1.jpg
I bought and then modified a 3/8 reproduction line for the feed which then comes up to the rail, the return I custom fabbed but it goes through an enlarged hole where the original went through and then runs down the subframe connector. I used the Aeroquip PTFE hose and ends. That's a GM type fuel filter you can get on Summit Racing that comes with push-on AN fittings. Regulator is the small Aeromotive one.
