After Market Fuel Gauge 1966 Dart?
coalman
Texas
Anyone use one, and if so which one? I just don't trust mine. Thanks
Are you going to try and install it in place of the original gauge? or just hang it off in a pod? makes a bit of difference since trying to find one that fits the original area might be a problem
if your hanging it get the matching sending unit so you can have a correct reading . autometer works.
Ok thanks, that was what I was worried about, I have a new sending unit in the tank. The gauge works it just acts like it has a mind of it's own. Thanks again...
You should be able to use one of the Auto Meter fuel level gauges that are calibrated to 73 ohms @ empty and 10 ohms @ full. They should work with your current tank sending unit and be pretty close to the factory gauge. Make sure that your tank sending unit has a good ground.
I ran a ground from the fuel tube on the sending unit to a ground on the unibody. I will check it. Did you splice the Auto Meter in and left the old one place, or just by passed the original? Thanks
There is a little strap, about 6 inches long, that goes from the fuel tank sending unit, over the rubber hose and clamps onto the fuel line. That would be your ground.
I haven't replaced the fuel gauge yet. It is on my list of things to do/get. I have to rebuild the steering coupler, replace the pinion seal, reinstall my engine, trans, clutch assembly, radiator, headers and new u-joints. Then it's gauges. Oh, and also the fuel filler tube restrictor.
Lots of things to keep me busy.
My car is no where near stock, rubber fuel hose in back, electric fuel pump. I know the part you are talking about. Thanks again
By the way, what are you building?
I have a real 1966 D/Dart. Actually I have 2 of them. The one that I am working on has a 360 in it now. The guy that I bought it from had changed the tired 275 hp 273 to a 380 hp 360 back in 1999. He never had it on the road that i know of. I've had it on the road a few times, about 20 miles total, and realized it needed some repairs. So I'm repairing it.
Great, I hope you enjoy them both!!!
I just put in an autometer 73-10 ohm in my 63. I also have an aftermarket sender in. I tried splicing it in and running in parallel with the existing fuel gauge but did not work - the autometer just kept cycling to half full and back. I suspect with two gauges it upset the resistance readings. I now just the run the autometer. Can't comment on accuracy yet only been in a month.
Thanks for the input...
reddog please let me know how it works, I am still tinkering with the factory one, as think I might have more of an electrical issue than anything else. Thanks
