yellow rose
Overnight Sensation
Best I can do. Can’t hold the light and the iPad and take the pictures. A couple of the heads too.
Should break the fuel up real good with that texture.
View attachment 1715673491 View attachment 1715673492 View attachment 1715673493 View attachment 1715673494 View attachment 1715673495 View attachment 1715673496
No kidding, I’m still not sold if it was a good idea or not having you go ape **** on my heads / intake. But we’re going to be finding out soon. I have to find a scatter shield that we can modify and add to my brother’s dyno to run some pulls.That’s not finished yet. I have to get all the carbide troughs out and the radii where I want them, then I’ll burr finish them.
I think after years of trying I’ve finally figured out how to use a burr finish and still get the shape I want, and not kill my hands doing it. I could be wrong. But I think I have a handle on it.
Scody21 is letting me do what I want on his stuff (he may be a bit on the crazy side for that, but I won’t judge him) so that’s why I’m giving it a shot. Closest I’ve been to getting it right I think and hope.
Heads will get the same, except I’m doing the exhaust port and the chambers with a burr finish too. Hopefully I’m not going off the rails...
Hopefully Scody21 will go back on the dyno with this when it’s done. If he does, I’ll let him borrow my SD to compare to this AG. I say the the SD would beat it up....
COOOOOOOOL. So this is going back on the pump!!! Fun fun fun.
Thanks for the documentation YR and what were the results on the dyno before? J.Rob
p.s. Any before or after flow results?
I should have the after flow numbers about the 3rd or 4th of February and then if Scody21 doesn’t care we can post them. Scody21 has some dyno numbers but that will be with iron heads and a different cam but maybe he will post them.
So the current 340 setup in the car now is...
1969 340 at .040 over with Fed Mogal L2316f-40 forged pistons, scat I beams.
J heads with 2.02/ 1.60 valves not ported, just machined, port cleaned new seats and valve job.
Comp cam 20-228-4 AKA XE285HL-10 xtreem high lift installed at 105.5 (yes we know, not a great cam selection. That’s why we’re changing it)
Comp springs at 1.65 at 140# open. running comp 1622-16 roller tip rockers and comp lifters. With the rest of the goodies like HV oil pump, air gap intake, MSD 6AL, pro billet distro, holly 750DP, mini starter, TTI step headers etc....
On the dyno, after brake in, adding the 2nd springs and dumping the green juice and adding fresh green juice (penn grade) we got the following on the Northwest Dyno services dyno, which is a Superflow 902.
382.8 TRQ at 4,400
364.4 HP at 6,000
We did run to 6,800, but the cam was tapering off at 6,300 and I can’t find the sheet from that run. .
You're peak numbers are exactly inline with what I would have expected and have witnessed more than once. Great info.
Are you going back to the same dyno facility? J.Rob
Glad it was you that wound up with that job!Updated pictures of your intake. Heads tomorrow.
View attachment 1715674339 View attachment 1715674340
I’ll get some better pictures tomorrow. I’ll hold the light and have the wife take the pictures
What????, I don't know no Johnny!!!, oh you mean that Johnny, ehhh his heads will be fine the way they are.You’re up next...Johnny needs a port job...
Think Loud Mouth’s mouth will make up for the lack of porting...What????, I don't know no Johnny!!!, oh you mean that Johnny, ehhh his heads will be fine the way they are.
Do you know the specs for your cam yet? I'm curious because that's what the focus of my car will be and I had Jones give me a recommendation for a SFT that would be a very racy for road course and auto-X but still streetable. Curious how your specs would compare. I happen to have a new XE275HL sitting on the shelf and I was going to use it until I do the four speed swap. The cam Jones specced was with a manual in mind and he said it wouldn't do well with an automatic.Thus why YR is porting the eddy heads and intake, we’re also going to change the cam for something that’s more auto cross / road race focused as that’s how I have this car set up. My 70 duster is going to be the 1/4 mile car...
How about some updates and closure by the end user on this.
I hear you. Thanks for replying. On the swapping in steps I know that’s what I tried to do up to a point as well but once things were that tore down I got real lazy thoughts and thought “I ain’t tearing all this apart again, screw it! All at once it is! Best of luck either wayBack from the dead. I’ve not swapped the heads yet. Life got in the way, with moving and such. As they say, if it aint broke, don’t fix it, my car runs really good as it is now.
I have a list of things I’m adjusting / changing this winter. I have dyno sheets for my current setup ran on a superflow 902, YellowRose is working on getting his 901 dyno off the ground. Are putting in a 236 .550 lift 107+2 Howard’s cam which took 10 weeks to get. I’m not sure if I’m going to just swap the heads / intake and do a few power pulls to see the increases vs. the current cam / 2.02 J heads. Then swap the cam, break-in and then run some power pulls.
