DartSwinger
- Joined
- Jun 24, 2008
- Messages
- 95
- Reaction score
- 0
Wanted to replace the stock snorkel air cleaner with an Edelbrock Pro-Flow triangle for a while.
Had hoses running from the valve cover breather to the air cleaner, then air cleaner NOX valve to the carb, so I put a one-way PCV between the breather straight into the carb.
Also following some suggestions, I plugged off the manifold preheat hole which connected by stovepipe to the snorkel.
Anyone see any problems with this setup? Thanks.
