Air conditioning off 2006 caravan
aarong5
Aaron Grimes
London Ky
To someone who knows what they are doing this may be the dumbest question I've ever heard, but I am parting out a 2006 Dodge Caravan that I use for work the air conditioning would freeze you out. is there any way to take everything off of the Caravan and somehow swap it all on to my 1967 barracuda?
I would not think so. It would be far more work.
A "backyard low budget" approach MIGHT and I'm saying MIGHT be........you'd have to custom build engine brackets.... (it use a sepentine belt, that's a BIG problem)
You might be able to fab up brackets and use the "underhood stuff" the compressor/ condenser, and then buy a cheap "underdash" evap box off ebay. You can find those fairly cheap. But you still would have to figure a way to make hoses.
I used the Denso compressor from a 95 Intrepid on my 68. They draw much less engine power than the V-twin but require a relay to keep from melting your control head. The hoses were just spliced with a little extra effort.... Still using the OEM under dash stuff and condenser.
i37333-jpg.1714918102
