air fuel mixture adjustment
o1heavy
1974 dart sport
tarkington
looking for some insight on adjusting air fuel mixture
engine is a smog 440 in a 78 D300
carb is a 750 vacum 750
engine seams to run best when the mixture scews are adjusted all the way in
does that mean i need to jet the carb down
thanks for any help
it means the engine is sucking air somewhere else........
make sure the secondary butterflys are just barely cracked and NOT open too much...then set the idle mix screws to about 1/2-3/4 turns out each. if it's still idling high...close the secondary butterflys more.
the adjustment screw for the secondary butterflys/blades is underneth the base plate on the diaphram side of th carb.
make sure the secondary butterflys are just barely cracked and open too much...then set the idle mix screws to about 1/2-3/4 turns out each. if it's still idling high...close the secondary butterflys more.
I do that adjustment on all the carbs I rebuild,good call.
