Rodsaknockin
Would you guys get your block align honed if you go with studs on your main caps and would you resize rods going from stock rod bolts to arp hardware?
Ok thanks I'm just debating going to a aftermarket rod it will be almost the same money as compared to resizing rods it is about 40 bucks for each rod and the arp bolts are 120.00 bucksYes and yes.
I never don't at least touch the main line regardless. And you never use new rod bolts without a resize unless they are caps crew style bolts.
I agree the block was ready to go plans changed a little and want to over build the bottom end a bit. I'm going to get the align hone done At a machine shop But with a new h beam Rod and arp hardware I should be safe on the rodsunless align honing is done by a really skilled and conscientous machinist with proper tooling, I think you can raise more problems than you're solving by the procedure, especially if it's just for using main studs.
That being said, I think resizing rods with a good rod honing machine is probably a good idea when going to new arp rod bolts. Again, they need to be honed by someone who knows what he's doing, because the rod is probably the most highly stressed engine component.
It is good to keep in mind there is no way to align hone without introducing more slop into the timing chain.I agree the block was ready to go plans changed a little and want to over build the bottom end a bit. I'm going to get the align hone done At a machine shop But with a new h beam Rod and arp hardware I should be safe on the rods
They are charging that 30 mins east of Lethbridge. That's after years of sending work this machinists way.Where in Canada are they charging about 40 a rod? Wow! I realize the buck sucks, but that's bad.
No that's just a resizeDoes that include full floating the small end?
So, that would be in Taber?They are charging that 30 mins east of Lethbridge. That's after years of sending work this machinists way.
Well I'm going to talk to joss technical in Lethbridge he seems like a honest sort and with my business stuff I use a guy in Calgary but he mostly does just pump stuff but I'm sure he will no someone good in the businessSo, that would be in Taber?
I'm looking for a good machinist in my area. (I'm in Lethbridge)
I really don't have too much faith in the shops in town here anymore, and it seems like the good guys have retired, and the rest.........well, you know.
P.M. me if you would like or just respond here.
The pricing makes it pretty attractive/easy to change to non-stock rods for a lot of applications.Ok thanks I'm just debating going to a aftermarket rod it will be almost the same money as compared to resizing rods it is about 40 bucks for each rod and the arp bolts are 120.00 bucks
Thank you.if you really want top quality machining get the best mopar guy in Canada . do what i do box it up and send it to J.Rob he goes by RAMM on this site .
Day and Ross provide cheap shipping . i sent him a complete small block once for $106.00 .
Joss does a lot of pump stuff too.Well I'm going to talk to joss technical in Lethbridge he seems like a honest sort and with my business stuff I use a guy in Calgary but he mostly does just pump stuff but I'm sure he will no someone good in the business
I know Anderson is a common name, but I used to know a Brad Anderson, who was an automotive machinist in Seattle 30 or so years ago. Any relation?Brad Anderson is just out of Calgary. He was the engine man for Les Davenport. U will be hard pressed to find anyone better out that way. Bruce at Abs in Regina Sask is 1 of the best. My buddy in Lloydminster uses Lou at AMS in Edmonton. Kim
