GoodysGotaCuda
Mr. Goody
At the moment it looks like I'll be picking up a 4777 'Classic' Double Pumper, 650cfm for the 318. Never messed with a Holley really, I do have a book that I'll be reading up on. (If i dont get this 4777, i will be getting a 650 dp anyway so carry on lol)
Anyway the build is.
318 - .030
9.7:1 compression
91/100octane
Stock port J-heads, 2.02
Comp .480lift/280duration Hyd cam
Headers with cutouts
Performer RPM intake
(currently 650 Thunder AVS carb)
MSD 6A, Helicore wires, coil
Soon to be recurved distributor by FBO
Transmixer is a 904
3,500footbrake, 3,900flash 9 1/2" Dynamic
Low gear set
TF-2 shift kit
Rear is a 8 3/4
3.91 Clutch SG
1.9 60ft
8.9 1/8th
14.0 1/4 @ 95
3,600lbs
~5,000ft air (currently)
I'm looking to get a base of what jets and such I should put in. Very new to Holleys at the moment so play nice lol. I know there are a few different bodies out there, cams, jets, and a whole bunch of other things to tinker with. I'm looking for the best bang for buck really. Anyone give me a base on what size jets and such i should start with?
Looking for the guys who have messed with these to kinda head me in the right direction, 'you'll need a ___ jet kit, cam kit, etc, etc'
Thanks guys for any advice.
318 - .030
9.7:1 compression
91/100octane
Transmixer is a 904
Low gear set
TF-2 shift kit
Rear is a 8 3/4
3.91 Clutch SG
1.9 60ft
8.9 1/8th
14.0 1/4 @ 95
3,600lbs
