Crazy4408pac
N. Michigan
Would like some feedback on header choices. And what to look for when installing. Close to dropping in the 440 into my 72 Swinger.
Thanks
Thanks
I'm running an RMS Alterkation in my 74 Dart with a 440 with Mazzoloni 2 1/8" headers. I'm very happy with the combination.
I think mazz sells TTII'm running an RMS Alterkation in my 74 Dart with a 440 with Mazzoloni 2 1/8" headers. I'm very happy with the combination.
Well if you already have em, why buy new ones.
I see your point but you can only go so low and still have the correct travel amounts on the coil overs, unless you use shorter ones. if you already have the headers installed then you have to patch the holes and re-paint the engine compartment. Thats more $$, I agree with your view but you also have to take into consideration what oil pan you have too. In my case the pan is lower than the headers by at least a couple inches, and thats with a Charlie's pan made for the AlterK.
Called Bill. Only one he suggested were TTI. But doesn't he have something going with TTI?
